Form Wash and Form Cure Tech Specs
Form WashForm Wash L
Printer CompatibilityForm 3+, Form 3B+, Form 3, Form 3B, Form 2Form 3L, Form 3BL, Form 3+, Form 3B+, Form 3, Form 3B, Form 2
Dimensions26.2 x 29.3 x 34.0 cm
10.3 x 11.5 x 13.4 in
Height when open: 64 cm (25.2 in)
78.0 x 46.0 x 67.0 cm
30.7 x 18.1 x 26.4 in
Height when open: 113 cm (44.5 in)
Weight6.7 kg
14.5 lbs
56.7 kg (without solvent)
125lbs (without solvent)
Bucket Volume8.6 L37.9 L
10 US gal
Maximum Part Size14.5 × 14.5 × 17.5 cm
5.7 x 5.7 x 6.9 in
33.5 x 20 x 30 cm
13.2 x 7.9 x 11.8 in
Suggested Operating
Environment
Suggested 18—28 °C
Suggested 64—82 °F
Suggested 18—28 °C
Suggested 64—82 °F
Agitation MethodMagnetically coupled impellerMagnetically coupled impeller
Included Accessoriesa. Wash Bucket
b. Wash Basket
c. Hydrometer
d. Siphon Pump
e. Flexible Scraper
f. Scraper
g. Tweezers
h. Flush Cutters
a. Wash Bucket
b. Wash Basket
c. Electric Solvent Pump
d. Flexible Scraper
e. Scraper
f. Flush Cutters
g. Rinse Bottle
h. Gloves
i. Form 3 Build Platform Adaptor
Power Requirements90–240 V
2.0 A 50/60 Hz
50 W
100–120 V (NA), 220 - 240 V (EU)
1.0 A 50/60 Hz (NA), 1.0 A 50/60 Hz (EU)
Compatible SolventsIPA, TPM, WaterIPA, TPM, Water
Form CureForm Cure L
Dimensions26.2 x 26.2 x 34.0 cm
10.3 x 10.3 x 13.4 in
69.0 x 54.0 x 44.5 cm
27.2 x 21.3 x 17.5 in
Weight5.6 kg
12.4 lbs
24kg
53 lb
Turntable Diameter19.3 cm
7.6 in
39.5 cm
15.6 in
Maximum Part Height18.5 cm
7.28 in
32 cm
12.6 in
Operating TemperatureSuggested 18—28 °C
Suggested 64—82 °F
Suggested 18—28 °C
Suggested 64—82 °F
Maximum Cure Chamber80 °C
176 °F
80 °C
176 °F
Light Source13 multi-directional LEDs45 multi-directional LEDs
LED Power39 W70W
LED Radiant9.1 W36W
LED Wavelength 405 nm 375 nm, 405nm
6.0 A 50/60 Hz
144 W
100–120 V (NA), 220–240 V (EU)
15.0 A 50/60Hz (NA), 8.0 A 50/60Hz (EU)
