Automate Cleaning With Form Wash L
Streamline your 3D printing process to help you produce high-quality large-scale parts with less time and effort.
Set It And Forget It
Use the pre-programmed wash settings or save your own frequently used custom profiles to improve post-processing efficiency.
Compatible With All Formlabs Materials
Select your material from a list and let Form Wash L auto-clean your parts for the appropriate time.
Improved Agitation
Clean your parts thoroughly with 1.5x more agitation than the previous generation.
Informed Maintenance
The embedded solvent monitor and cycle counter help you maintain peak cleaning performance by notifying you when it’s time to replace the solvent.
Adaptable to Build Platforms
Seamlessly switch between build platforms with adjustable platform mounts, configurable at various heights and widths.
One Size Fits All
Wash one Form 4L Build Platform or two Form 3/B/+ or Form 4/B Build Platforms with adjustable platform mounts.
Form 4BL Workflow in Minutes
Form Cure L is part of a 3D printing ecosystem that’s easy to learn and use, and requires little intervention or maintenance. Watch the video to learn the basics of how to use Form 4BL, from software, to materials, printing, and post-processing.
Tech Specs
| Form Wash V2 | Form Wash L V1 | Form Wash L V2 | ||
| Printer Compatibility | Form 4, Form 4B, Form 3/+, Form 3B/+, Form 2 | Form 3L, Form 3BL, Form 3/+, Form 3B/+, Form 2 | Form 4L, Form 4BL, Form 4, Form 4B, Form 3L, Form 3BL, Form 3/+, Form 3B/+, Form 2 | |
| Dimensions | 31.5 x 29.3 x 40.5 cm 12.4 x 11.5 x 15.9 in Height when open: 71.4 cm (28.1 in) | 78.0 x 46.0 x 67.0 cm 30.7 x 18.1 x 26.4 in Height when open: 113 cm (44.5 in) | 78.0 x 46.0 x 67.0 cm 30.7 x 18.1 x 26.4 in Height when open: 113 cm (44.5 in) | |
| Weight | 8.6 kg (without solvent) 18.9 lbs (without solvent) | 56.7 kg (without solvent) 125lbs (without solvent) | 56.7 kg (without solvent) 125 lb (without solvent) | |
| Bucket Volume | 14.4 L 3.8 US gal | 37.9 L 10 US gal | 37.9 L 10 US gal | |
| Maximum Part Size | 20 x 14.5 x 19.5 cm 7.9 x 5.7 x 7.6 in | 33.5 x 20 x 30 cm 13.2 x 7.9 x 11.8 in | 35.3 x 20 x 29.6 cm 13.9 x 7.9 x 11.7 in | |
| Suggested Operating Environment | Suggested 18—28 °C Suggested 64—82 °F | Suggested 18—28 °C Suggested 64—82 °F | Suggested 18-28 °C Suggested 64-82 °F | |
| Agitation Method | Magnetically coupled impeller | Magnetically coupled impeller | Magnetically coupled impeller | |
| Included Accessories | a. Wash Bucket b. Wash Basket c. Hydrometer d. 2x Platforms Mounts | a. Wash Bucket b. Wash Basket c. Electric Solvent Pump d. Flush Cutters e. Rinse Bottle f. Gloves i. Form 3 Build Platform Adaptor | a. Wash Bucket b. Wash Basket c. Electric Solvent Pump d. Flush Cutters e. Rinse Bottle f. Gloves | |
| Power Requirements | 90–240 V 2.0 A 50/60 Hz 50 W | Input (NA) 100 - 120 VAC, 50-60Hz, 1A Input (EU) 220 - 240 VAC, 50-60Hz, 1A | Input (NA) 100-120 VAC, 50-60 Hz, 1 A Input (EU) 220-240 VAC, 50-60 Hz, 1 A | |
| Compatible Solvents | IPA, TPM, Water, Formlabs Resin Washing Solution | IPA, TPM, Water, Formlabs Resin Washing Solution | IPA, TPM, Water, Formlabs Resin Washing Solution |
| Printer Generation | Applicable Build Platforms | # Build Platforms That Can Fit on Form Wash L V2 | ||
| Form 2 Form 3/B/+ | Standard Build Platform Build Platform 2 Stainless Steel Build Platform | 2 | ||
| Form 3L/BL | Form 3L Build Platform Form 3L Build Platform 2L | 1 | ||
| Form 4/B | Form 4 Build Platform Form 4 Build Platform Flex | 2 | ||
| Form 4L/BL | Form 4L Build Platform Form 4L Build Platform Flex | 1 |
