Effortlessly create parts for any dental application. Print any resin with Open Material Mode.
Blazing Fast Post-Processing
From print to final part in as little as 6 minutes*
11 models
in 9 minutes
5-10
minutes
1-10
minutes
Effortless, Mess-Free Cleaning for Perfect Parts
Washing
How the Wash Works
Form Wash and Form Wash L provide thorough cleaning with powerful agitation to ensure residual resin is completely removed. After the preset wash cycle, the parts are automatically lifted from the bath to air dry.
Washing
Powerful Agitation
Let Form Wash auto-clean your parts faster with powerful agitation to clear every nook and cranny.
Washing
Adaptable to Build Platforms
Seamlessly switch between build platforms with adjustable platform mounts, configurable at various heights and widths.
Washing
Flexible Solvent Volume
Tailor the solvent volume to the size and quantity of your parts. Use lower solvent quantities for smaller parts and builds to increase resource efficiency.
Washing
Compatible With Variety of Solvents
Our recommendation is to use IPA for the best cleaning experience. Alternative solvents such as TPM and Formlabs Resin Washing Solution are also compatible with Form Wash.
Optimal Accuracy in Record Time
Curing
How the Cure Works
Form Cure and Form Cure L use powerful LEDs, convective heating, and validated presets to achieve optimal mechanical properties with speed and precision.
Curing
Why Post-Curing Matters
Post-curing improves your part on a molecular level. 405 nm light initiates a reaction that cross-links the individual polymers, creating an interconnected, isotropic, and 100% dense final part.
-Safer biocompatible workflow
-Higher accuracy
-Stronger appliances
-Higher surface hardness
Curing
Blazing Fast Curing, Nearly Instant Heat Up
Cure any Formlabs dental material in 10 minutes or less.
Curing
Consistent, Validated Results
Pre-programmed and validated cure settings let you safely cure biocompatible resins, without guesswork.
Curing
Cure 15 Models per Minute
One cure unit serves multiple continuous Form 4B printers. Technicians no longer need to walk away from the unit due to the rapid curing of dental models.
Curing
Easier Than Ever
Sleek new design with an easy to clean glass turntable, eliminating the need to flip parts midway through the curing cycle. The side-opening provides convenient access within a compact footprint, while the high clearance allows for effortless part placement and removal.
Set It and Forget It
To Unlock Peak Performance
Choose your Ecosystem
For Form 4B and Form 4BL
Form 4B Package
Form 4BL Package
* Based on a five minute wash, a quick dry using compressed air, and a one minute cure for model resins.
