With the release of Form 4BL, we dramatically sped up stereolithography (SLA) 3D printing. Now, with the release of Form Cure L V2, we’re cutting down the time it takes to post-process, so you can achieve peak mechanical properties in record time.
For biocompatible materials, post-curing is necessary to achieve the safety standards set by regulatory agencies, as well as dimensional accuracy and peak mechanical properties. For dental and orthodontic labs demanding high throughput in record time, Form Cure L delivers up to 5-6x faster post-curing of more parts, for faster delivery of models and appliances with less labor.
Consistent, Validated Results Up to 6x Faster
The new Form Cure L is up to 6x faster. Models printed in Fast Model Resin or Precision Model Resin take just one minute to cure, while occlusal splints printed in Dental LT Clear Resin take just 10 minutes, for 6x less post-curing time. Plus, Form Cure L takes just 150 seconds to heat to 60 °C*, 40% faster than the previous version.
Streamlined workflows and presets empower consistency. Form Cure L has presets for 15+ Formlabs Dental Resins, plus the ability for expert users to program their own settings.
*(230 V version)
Presets for all Formlabs Dental resins makes it easy to deliver consistent results.
| Resin | Time in Form Cure L V1 | Time in Form Cure L V2 | Time Savings |
| Fast Model Resin | 5 min | 1 min | 80% |
| Precision Model Resin | 5 min | 1 min | 80% |
| Dental LT Comfort Resin | 20 min | 7 min | 65% |
| Dental LT Clear Resin | 60 min | 10 min | 83% |
| Premium Teeth Resin | 30 min | 5 min | 83% |
The updated Form Cure L features 96 multi-directional LEDs. A convective heating system ensures uniform light and heat exposure, delivering 14.5 mW/cm² irradiance and a maximum temperature of 100 °C.
Easier Than Ever
The sleek new design has a 26% reduction in overall footprint from the previous generation, while having a 353 x 196 x 350 mm interior. Cure parts on a 404 mm glass turntable accessed via a side-hinged door. This redesign enables a compact workspace and a more ergonomic workflow.
Fit all the parts from a Build Platform L or cure parts from multiple Form 4B Build Platforms.
Formlabs Dental is dedicated to making the end-to-end SLA 3D printing workflow easy and intuitive so you can provide customers and patients with appliances and restorations with a perfect fit. With the release of Form Cure L, it’s easy to go from pressing print all the way to cured parts with ease — saving labor along the way.
Add Form Cure L to your workflow.
