Post-Cure Models in 60 Seconds With the Blazing Fast Form Cure (2nd Generation)
Your dental 3D printing workflow just got faster — introducing Form Cure (2nd Generation), offering blazing fast curing for any dental part in 1-10 minutes for faster time to part and consistent, validated results, so you can deliver dental parts in record times.
In addition to the release of Form Cure (2nd Generation), new printer fleet features have been added to Dashboard, simplifying collaboration, streamlining workflows, and increasing productivity. Additionally, PreForm Dental now includes a 100 μm layer print setting for Precision Model Resin for faster production of restorative models.
Post-Cure Models in 60 Seconds With Form Cure (2nd Generation)
Table in dental lab with a Form 4B, Form Wash (2nd Generation), and Form Cure (2nd Generation)
The complete Form 4B ecosystem: Form 4B, Form Wash (2nd Generation), and Form Cure (2nd Generation).
Form Cure (2nd Generation) offers blazing fast curing for any dental part in 1-10 minutes, saving up to 50 minutes from the cure time with the original Form Cure. Form Cure (2nd Generation) heats to 60 °C in just 60 seconds*, saving valuable workflow time.
*Based on the 230 V version. The 120 V version will heat to 60 °C in 90 seconds.
“The pre-programmed settings make working with the new Form Cure super easy, and of course the speed is fantastic."
Dr. Rick Ferguson DMD, DABOI, DICOI, FACD, Implant Educators Academy
Come up on Form Cure (2nd Generation) with transparent orange-colored door
Form Cure (2nd Generation) appears orange when it is not actively curing.
Close up on Form Cure (2nd Generation) with restorative dental models inside. The door is transparent purple as curing is in progress.
When Form Cure (2nd Generation) is in use, the window appears purple, so you can see, at a glance, that it’s curing.
Form Cure (2nd Generation) delivers consistent results for Formlabs Dental resins with pre-programmed and validated cure settings. Safely cure biocompatible resins without guesswork and a workflow that is easier than ever — simply select the resin and start the cycle. For curing third-party materials printed with Open Material Mode (OMM), it’s possible to save custom profiles for the resins you regularly print, or set the time via the dial.
MaterialForm Cure (1st Generation)Fast CureForm Cure (2nd Generation)
Precision Model Resin5 min30 s1 min
Fast Model Resin5 min1 min1 min
Surgical Guide Resin30 min5 min5 min
Dental LT Clear Resin V260 min6 min10 min
With a larger build volume than both Form Cure and Fast Cure, Form Cure (2nd Generation) can fit 15 models, for a throughput of 15 models per minute. With this capacity, one cure unit can serve multiple Form 4B printers while decreasing the number of interactions required.
Form Cure (2nd Generation) is designed for easy operation in small workspaces. The door opens from the side, allowing easy access within a compact footprint, while high clearance enables easy part placement and removal. Additionally, the sleek new design and glass turntable are easy to clean.
Maximum Part Height185 mm65 mm 245 mm
Turntable Diameter193 mm
7.6 in
180 mm
7.1 in
235 mm
9.25 in
Maximum Cure Chamber Temperature 80 °CN/A100 °C
The blazing print speed of Form 4B combined with the time savings of Form Cure (2nd Generation) allow the production of occlusal splints at 100 μm layer height more than 4.8x faster than with Form 3B+ and Form Cure.
Time to manufacture occlusal splints at 100 μm layer height with Dental LT Clear Resin V2
Number of partsPrint time Wash timePost-curing time Total time
Form 4B & Form Cure (2nd Generation)849 min 15 min10 min1 h 14 min
Form 4B & Form Cure (1st Generation)849 min15 min1 h2 h 4 min
Form 3B+ & Form Cure (2nd Generation) 74 h 45 min15 min10 min5 h 25 min
Form 3B+ & Form Cure74 h 45 min15 min1 h6 h
Form Cure (2nd Generation) is compatible with Form 4, Form 4B, Form 3/B/+, and Form 2 and replaces both Form Cure and Fast Cure in our dental ecosystem.
Fleet Control Management Features Now in Dashboard
If you have a fleet of Formlabs 3D printers, it’s now possible to manage and monitor the entire fleet via one centralized dashboard. This simplifies collaboration, streamlining workflows and increasing productivity. These previously paid features — called Fleet Control — are now free and integrated into Dashboard, giving all users access to Group Queues for automated print assignment, Cloud Slicing for faster processing, and Bulk Firmware Updates for seamless printer maintenance, all in one easy-to-use platform.
New Dashboard updates include:
  • Group Queues: Print jobs can be sent to a shared queue, and the next available printer will automatically start the job.
  • Cloud Slicing: Print files can be processed in the cloud instead of locally, reducing the strain on a user’s computer.
  • Bulk Firmware Updates: Users can update all their printers at once, rather than one at a time.
These updates enable streamlined printing and easy team collaboration, so you can:
  • Monitor prints in real-time
  • Manage multiple printers from one interface
  • Track resin usage, print history, and maintenance needs
“There is the world of dental 3D printing and then there is Formlabs. When you have multiple 3D printers — and this is the future for dental — you need a good way to manage all those 3D printers. And there is nothing close to the Dashboard and the ecosystem from Formlabs.”
Dr. Antonino Cacioppo, DDS, PhD, Prosthodontist
To start using these features, sign up for Dashboard or log in to your account.
Improving Speed & Throughput
From print setup through post-curing, we’re constantly optimizing workflow efficiency, ease of use, and increasing time-savings so you can efficiently and cost-effectively provide patients with the best possible care.
Speed up your curing with Form Cure (2nd Generation) or contact a dental specialist to discuss your unique business goals.
