Announcing New Denture Base Resin for Lifelike Dentures That Deliver Long-Term Performance
Introducing the new Denture Base Resin V2, a high-impact, long-term biocompatible material for producing strong, lifelike dentures that exceed ISO 20795-1 standards. The new formulation is tougher, with more lifelike aesthetics and substantially faster processing times, for less labor and a low cost per part. With the release of this updated formulation, dental professionals can print full dentures on Formlabs Form 4B and Form 4BL 3D printers using a streamlined, validated process.
"The Form 4 combined Formlabs' accuracy with speed, and now comes the next generation of denture base material — a high-accuracy denture base that supports all the important steps you expect from a denture base."
Dr. Michael Braian, DDS, CDT, PhD, Founder of the Swedish Organisation for Computer Aided Digital Dentistry (SWECADD)
Available in three semi-translucent pink shades, new Denture Base Resin empowers denturists and technicians to deliver tough, lifelike dentures with confidence.
Form 4B 3D printer
Get in Touch
Whether you need to produce occlusal splints in-house, or are looking for high-throughput production of dental models, we're here to help. Get in touch with a dental expert to find the right solution for your business.
Adaptive, Lifelike Aesthetics
denture base resin v2
New Denture Base Resin is available in three shades: Original (at left), Light (middle), and Dark Pink (right).
Available in three semi-translucent pink shades – Original, Light, and Dark Pink – the material's optimized translucency blends naturally with patient tissue for gingiva that looks and feels authentic. Users accustomed to Lucitone Digital Print will find the aesthetics familiar.
Deliver dentures with the impact-resistance to withstand everyday wear and accidental drops. New Denture Base Resin is strong enough to withstand mastication. With a fracture toughness of 2.43 MPa.m1/2 and a work of fracture of 1,000 J/m2, the material is considered high-impact, making it resistant to crack propagation from accidental drops. The improved mechanical properties enable technicians and denturists to deliver dentures with long-term performance.
Denture Base Resin has the compatibility to be relined with a range of hard and soft materials and repaired using standard repair methods, giving dentists and lab technicians the confidence to guarantee their work for years of patient wear.
Denture Base Resin vs. Lucitone Digital Print
Formlabs Denture Base Resin is comparable to Lucitone Digital Print 3D Denture Base, with flexural and toughness properties that exceed ISO 20795-1 standards and a translucency of ~35%, for more realistic aesthetics than traditional denture bases.
Formlabs Denture Base Resin V2 printed on Form 4B, 100 μm layer height
Dentsply Lucitone 3D Denture Base printed on Form 4B, 100 μm layer height*
Flexural Strength
(ISO 20795-1, in water > 65)
67 MPa
>65 MPa
Flexural Modulus
(ISO 20795-1, in water > 2000)
2,240 MPa
>2,000 MPa
Fracture Toughness (ISO 20795-1 > 1.9)
2.43 MPa.m1/2
2.50 MPa.m1/2
Work of Fracture
(ISO 20795-1 > 900)
1,000 J/m2
>900 J/m2
*Data published by Dentsply
denture base resin v2 vs lucitone
Dentures made with Lucitone 3D Denture Base (left) and Denture Base Resin V2 (right).
Dentsply has published settings for printing Lucitone 3D Denture Base on Form 4B by using Open Material Mode (OMM). However, printing with Lucitone 3D Denture Base Resin requires manually pouring the resin into the resin tank. By contrast, Denture Base Resin comes in a Formlabs cartridge, for automatic resin dispensing on Form 4B and Form 4BL, and at a lower price point. Additionally, Denture Base Resin V2 is the only denture base material with print settings available for large-format Form 4BL 3D printers.
List price per liter*
$549
$1,008
List price per kilogram
$500
$917
Cost per denture base
$12
$22
*Bulk resin discounts are available.
Lower Costs With Digital Dentures
Labor is the most costly part of denture production. By 3D printing denture bases, technicians and denturists can save half an hour to an hour and a half of work per denture, while fully digital denture workflows save almost 60% over traditional workflows. Even 3D printing the denture base and using stock teeth can save almost 50% over pouring or milling bases.
TRADITIONAL POURED
MILLED
3D PRINTED BASE, STOCK TEETH
FULLY 3D PRINTED
Denture base material cost
$2
$35
$9
$9
Denture teeth material cost
$30
$25
$30
$5-9
Hours of technician labor
2.5
1.5
1
1
Hourly cost of technician labor ¹
$25
$25
$25
$25
Material and labor cost
$95
$98
$64
$39-43
¹ NADL 2019 Business Survey
Produce Digital Dentures With a Streamlined, Validated Workflow and Less Labor
Reach the final denture in fewer steps without additional equipment. Denture Base Resin comes in a Formlabs auto-dispense cartridge, for no-mess printing, and is fully validated on the Form 4B/BL Ecosystem.
MS-Graph for Denture Base Resin V2
Processing times taken from Dentsply Lucitone 3D Denture Base and Denture Base Resin V2 Instructions for Use.
It takes 2 h 30 min to print six denture bases on Form 4B (or 1 h 47 min to print just one), followed by a 10-minute IPA wash, and 30 minutes of air drying.
At this point, dentures can be assembled in 10-20 minutes using Denture Base Resin as a bonding agent if using printed Premium Teeth Resin denture teeth. Once assembled, dentures are post-cured in Form Cure for 20-minutes.  Previous versions of this resin required a three-hour post-cure process involving submerging the part in preheated glycerol. The new Denture Base Resin has a 9x faster cure time with fewer steps. Once post-cured, finishing and polishing take 10 minutes, for a total time of less than four hours to print and assemble.
Six denture bases can be printed on Form 4B in 2 h 30 min.
Parts printed with Denture Base Resin V2 only require a 10-minute IPA wash.
Denture bases are post-cured in 20 minutes in Form Cure V2 (30 minutes in Form Cure V1).
Denture bases printed with Denture Base Resin V2 offer flexibility and are compatible with teeth printed with Formlabs Premium Teeth Resin, milled teeth, stock or carded teeth, or other 3D printed teeth. To assemble dentures with Premium Teeth Resin, liquid resin can be used as a binder. For other teeth, third-party binders such as Ivoclar Ivotion Bond Kit can be used.
Download the Instructions for Use for the complete manufacturing guide.
Case Study: Like Using PMMA
A denturist for over 30 years, Rob Bredewoud of Dental Design Vof has stayed on the cutting edge of dental innovations, testing hardware and materials from a range of manufacturers and teaching workshops on digital dentistry. When it came time to release a new Denture Base Resin, Formlabs Dental had Bredewoud do some tests.
“Denture Base Resin V2 is a great product to see — aesthetics-wise, it’s perfect. Technically, it's very nice to work with; polishing is very nice, it's almost like you're using a traditional PMMA.”
Rob Bredewoud, Denturist, Dental Design Vof
Bredewoud’s business is fully digital, delivering 150-200 cases a year to patients in the Netherlands. He finds that Denture Base Resin V2 has similar aesthetics to Lucitone 3D Denture Base, and appreciates the ~35% translucency. Additionally, he finds that grinding bases printed with Denture Base Resin feels good — like working with PMMA — and there’s no chipping during the process.
Start Printing New Denture Base Resin
New Denture Base Resin offers lifelike aesthetics and long-term biocompatible performance — all at a lower cost per part than competitors. Streamlined workflows with the Form 4B/BL Ecosystem minimize labor, mess, and time to delivery. Plus, impact resistance and broad support for hard and soft relining materials mean denturists and technicians can confidently guarantee their work for years of patient wear.
Buy new Denture Base Resin to start printing dentures on your Form 4B or Form 4BL, or contact a reseller to learn more.
WhitePaperCta
